Engine improves with mileage
- Thank you received: 81
25 Sep 2020 12:43 - 25 Sep 2020 12:44 #228529
by lightning
Replied by lightning on topic Engine improves with mileage
l've never done more than 65mph in our Jimny, don't see the point really
That's the speed my 110 likes to cruise at so l am used to it, doesn't make much difference to arrival times and it's a lot more relaxing than hammering down the outside lane ten feet behind the Audi that won't move over.
Last edit: 25 Sep 2020 12:44 by lightning.
- zebraman
25 Sep 2020 12:52 #228530
by zebraman
Replied by zebraman on topic Engine improves with mileage
Ours has done 1500 miles and it is a lot less boomy on the motorway. Can cruise at 70 without going mad now.
- AlexK
25 Sep 2020 14:00 #228533
by AlexK
Replied by AlexK on topic Engine improves with mileage
The gearchange on mine was a little truculent to begin with, which was a surprise as the Gen4s I'd driven before all had a sweet action. Engaging first from a standstill was often particularly tricky.
Over time it's loosened up nicely to the point that it's now as fluid as I remember on those first drives.
25 Sep 2020 18:51 #228554
by Foxtrot
Replied by Foxtrot on topic Engine improves with mileage
I have noticed that the engine feels like it has a lot more torque after 1000 miles, I am hoping it loosens up even more after another couple of thousand..
26 Sep 2020 09:42 #228564
by Busta
Replied by Busta on topic Engine improves with mileage
It's quite normal. It's partly due to everything "bedding in". Wear is highest in the initial stages of using an engine, and they are manufactured in such a way that the engine reaches it's optimum once this wear has taken place.
Another not insignificant factor is the human one. Over time you learn how to drive the car. Most of it is subconcious. Builiding up muscle memories makes you a smoother operator, you ear becomes attuned to the noises that matter and blanks ot the ones that don't and you adapt to how the car likes to be driven.
The following user(s) said Thank You: Foxtrot
26 Sep 2020 14:40 #228571
by lightning
Yes l need to get used to driving a 16v petrol engine, after driving a Land Rover diesel that red lines at 4,500rpm and rarely needs to go over 2,500.
By the time you reach the maximum power in the Jimny it sounds like the pistons want to escape from the engine block.
Although it's surprisingly good when driven like a Land Rover, not exceeding 2,500rpm
Time to create page: 1.698 seconds
