M13A head gasket change
- MikeJames2
12 Jul 2020 14:03 #224897
by MikeJames2
M13A head gasket change was created by MikeJames2
Hi all,
I have a Jimny which overheats after a motorway run. After changing the thermostat, radiator and topping up the viscous fan fluid to no avail I did a gas-in-water check which came back positive so I will change the head gasket.
The workshop manual suggests I need to remove the oil pan. Can anybody tell me why I need to do this?
12 Jul 2020 14:38 #224899
by sniper
Replied by sniper on topic M13A head gasket change
A guess would be to ensure that there is no water contamination. Service instructions always err on the side of caution.... not a bad path...
sniper
sniper
- Thank you received: 1876
12 Jul 2020 15:12 #224905
Replied by Lambert on topic M13A head gasket change
According to the garage that did mine the sump has to come off as its impossible to seal the front cover otherwise.
- MikeJames2
12 Jul 2020 19:24 #224944
by MikeJames2
Replied by MikeJames2 on topic M13A head gasket change
Good idea about the water. I'd never considered that.
If it is required to seal the front cover then I guess I need to do it.
I've only just cleared the last oil spill off the drive!
Thanks all
Thanks all
13 Jul 2020 12:01 #224991
by Keithy
Replied by Keithy on topic M13A head gasket change
I'd remove the engine to do it......saves loss of temper and in the long run it's easier.
The sump front cover would be interesting to get right....the dowels are the problem
- MikeJames2
14 Jul 2020 16:18 #225077
by MikeJames2
Thanks for the advice Keithy.
Trouble is i've always said that if I take out the 1.3 I will be putting a 1.6 back in! This is a dilemma
