EGR valve advice
- Gardiner
23 Jun 2020 18:24 #223906
by Gardiner
EGR valve advice was created by Gardiner
My wife owns a Jimny VVT late 2006 model.
She recently experienced the engine coughing and spluttering and Almost cutting out on occasion.
Local garage ran diagnostics and came to the conclusion it was the EGR valve at fault and either needed cleaning, blanking off or replacing!
The clean or the blanking off doesn't seem to have worked because she is still having issues (all be it not quite as bad) with the car coughing and spluttering. It looks like maybe we need a new EGR? This is an expensive option £420 fitted we've been quoted! Any advice please before we spend even more money?
23 Jun 2020 19:49 #223912
by Scimike
Replied by Scimike on topic EGR valve advice
Hi,
It's a tricky one this as some symptoms of a failing EGR valve can also be produced by ignition and sensor faults, most of which don't cause a diagnostic code or engine light. If the garage has come to this conclusion via a specific fault code then it's likely they are correct, but I have never seen anyone mention a EGR fault code during my time on the forum. That's the problem, EGR failure appears to be not a common fault on the Suzuki engine, usually it's electrical.
You may need to wait a few days to get the full experience from the forum members, so this post will mainly just jump you back to the top.
Have you asked them why they think it's the EGR valve, they must have a reason?
- Thank you received: 1958
23 Jun 2020 20:42 #223915
Replied by Lambert on topic EGR valve advice
I too would suggest those symptoms were cam and or crank position sensors or maybe idle control valve related not exhaust gass recirculation? As said above are we certain of the garage diagnostics?
- CC Baxter
24 Jun 2020 15:18 #223946
by CC Baxter
Replied by CC Baxter on topic EGR valve advice
EGR problems are more common in high performancs engines (increased flow) and far less common in a low state of tune Jimny. Of course they could be right, but sensors and a cleaned idle valve are relatively cheap. Chris
Time to create page: 0.195 seconds
