Electrics question - inverter amps
  • CC Baxter
26 May 2020 15:59 #222850 by CC Baxter
Replied by CC Baxter on topic Electrics question - inverter amps
I've used an inverter on a boat but that was powered off 4x 90ah batteries and a complicated wiring system, quite effective. What a Jimny battery can achieve I shudder to think. Chris
26 May 2020 16:09 #222851 by me101
I think it is safe to assume they shouldn't come with that type of plug then. Will be going to a 2nd battery (will put something on here when finished!)
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
26 May 2020 17:15 #222854 by Riccy
The cig socket fuse is 15a (180w), so the invertor isnt being used at its peak, or is lying about its abilities. If the cable fitted to it is relatively small (2.5mm say) then its probably best to fit a fuse according to that, If you can replace the cable then, as others say, use a larger cable (6mm would probably be about right on a 30a fuse). You want tri-rated flex or welding cable, rather than some domestic 230v twin & earth stuff mind ;-)
I would bet more that the invertor is unlikley to be able to produce the indicated power, and certainly not for long. A common thing with electronics like this.
Time to create page: 0.445 seconds
