What Underseal should I use??
- Olliecarr25
25 May 2020 08:58 #222801
by Olliecarr25
What Underseal should I use?? was created by Olliecarr25
Hi there I want to underseal my 2002 jimny and am wondering what’s the best underseal to use I have already purchased some rust converter to put on first thanks.
25 May 2020 10:30 #222803
by sniper
Replied by sniper on topic What Underseal should I use??
If you are keeping the car, don't use a pitch type underseal that doesn't dry. They are a bugger to clean off for further repairs, later down the road....
Buzzweld gets rave reviews but is a tad pricey....
sniper
sniper
25 May 2020 10:37 #222804
by Scimike
Replied by Scimike on topic What Underseal should I use??
Hi,
I use a Tetraschutz type underseal, but spray it on using a Schultz gun. I only use this to repair the OEM high impact areas, but only after all the rust has been removed and an anti rust primer has been applied.
BUT I would not use it as an anti rust covering on the underside of my Jimny, for this I believe you are better using a wax product. I favour black waxoyl as a covering direct, it works even better direct to rust converter. I have seen that it does keep further rust at bay and does not hide any further rust that may develop.
Plenty of wax products available, any is better than nothing, so you can't really go wrong.
Mike
Mike
25 May 2020 15:20 #222813
Replied by yakuza on topic What Underseal should I use??
Here in Norway the only products really competing with wax / oil based products is either lanolin base or linseed oil base.
Some products that form a too hard shell will crack faster and not seal, some products too soft will wear off faster.
Most important is to do it and not postpone..
- Thank you received: 96
25 May 2020 15:46 #222815
by DAGZOOK
Replied by DAGZOOK on topic What Underseal should I use??
Check out my thread:
www.bigjimny.com/index.php/forum/18-buil...tion?start=24#222808
I used a brand called BILT HAMBER. Top stuff.
25 May 2020 16:10 #222816
by RainerK
Replied by RainerK on topic What Underseal should I use??
I used a fat-based product Mike Sanders. I think it is great, especially if the area is not new, but whenever you do something to the car`s underside your handy get full of fat.
Time to create page: 0.216 seconds
