Help - Roll Cage Install....
- Thank you received: 305
11 Apr 2020 10:55 #220932
by sniper
Help - Roll Cage Install.... was created by sniper
I am having a cage fitted and need some pictures of cage installs that have the front legs going through the top of the wing......
The tube goes down the "A" pillar and then joins the structural steel on the lower "A" pillar, behind the front wing, then triangulated to the chassis.
The guys at the workshop will be fitting it without me being present and I want to get as much info for them as possible...
Also, if anybody has any pictures of tidy tray-backs, it would help to see those also.
Thanks in advance,
sniper
Thanks in advance,
sniper
- X8GGY
11 Apr 2020 14:47 #220950
Replied by X8GGY on topic Help - Roll Cage Install....
This is one of my old Vitaras - "Superzuki" that started this obsession of mine - with a cage that went though the top of the A-pillars...
The end of the tubes sat on steel plate bolted to the top of the wings. with the outer skin neatly trimmed around the tubes...
That prompted JackOnlyJack to ask for these questions of the landing area -
Might help?
Most people have them external and running down to a sill side bar, but I've (personally) never like the "climbing frame" look...
Might help?
- Thank you received: 706
11 Apr 2020 14:58 #220952
Replied by jackonlyjack on topic Help - Roll Cage Install....
This is what i was thinking about sniper
square 5-6mm plate in purple
then bar welded to it
also thinking of bolting plate to the part of A pillar
it's a bit rough but you get the idea
11 Apr 2020 15:33 #220954
by sniper
Replied by sniper on topic Help - Roll Cage Install....
Thats just about perfect Jack, thanks mate.....
sniper
sniper
- X8GGY
11 Apr 2020 15:43 #220955
You'd be better off having an upside down L shaped plate that landed on top as well rather than 'just' bolting to the side?
There's only 60mm from where the hinge is sitting in the photo to the outer skin of the bolted-on wing...
11 Apr 2020 15:49 #220956
My cage idea is more to protect windscreen (not for roll over)
So my tube will be 38-45mm o/d
Time to create page: 0.107 seconds
