2007 stuck in 4wd
04 Apr 2020 15:47 #220684 by me101
2007 stuck in 4wd was created by me101
Hi, just need pointing in the right direction please. Little Jim is stuck in 4wd, with the green dash light flashing.Tried reversing but done nothing. Currently on axle stands, done a visual check on the pipes and they seem fine. Just ordered an E10 Torx so I can take the cover off. I have unplugged the connectors on the transfer box and cleaned them. I thought I had seen a post somewhere about bridging something on the 4wd controller to fool the transfer box into 2wd again?
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
04 Apr 2020 19:56 #220703 by mlines
Replied by mlines on topic 2007 stuck in 4wd
Couple of things you can try:
1. Give the solenoid on the transfer box a good clunk with a hammer.
2. Short out the vacuum switch leads (white ones) underneath the front of the battery tray
04 Apr 2020 20:08 #220704 by me101
Replied by me101 on topic 2007 stuck in 4wd
Thanks, will try in the morning. Cheers
05 Apr 2020 10:29 #220711 by me101
Morning,
unfortunately they were both a no go.
Cheers
07 Apr 2020 13:04 #220776 by me101
Need some new suggestions, have removed part of transfer box and manually put the box into 2wd. Still got the flashing light, and now stuck in 2wd. Have pulled the vac pipes off under car and joined them, no difference. Thanks.
07 Apr 2020 13:46 #220778 by sniper
Replied by sniper on topic 2007 stuck in 4wd
Re-read Mlines post, you don't join the vacuum pipes...... The vacuum pressure sensor is below the battery on the inner wing, all the vacuum pipes go to it. It has a white plastic two pin plug, remove the plug, bridge the two wires in the plug with a loop of wire, tape in place.
That gives the "Vacuum Present" signal to the transfer box.....
sniper
Time to create page: 2.621 seconds
