Wire colours for the radio
  • Louisd9
02 Apr 2020 14:01 #220581 by Louisd9
Wire colours for the radio was created by Louisd9
Hi everyone, hope you are all well during this pandemic, I am currently trying to change my radio to an aftermarket radio in my 2006 Jimny and I am having trouble figuring out what colour wire does what, I cannot find it anywhere not even in the Manual... For example, I have never seen a red and green wire?? or yellow and red? Anyone have any ideas? or a diagram?
Thanks
Louis
02 Apr 2020 15:00 #220583 by yakuza
Replied by yakuza on topic Wire colours for the radio
No eBay APP ID and/or Cert ID defined in Kunena configurationan iso adapter for Suzuki will make your new stereo plug right in.
f.ex:
most car parts stores or car stereo store have this..
If you already cut the plugs, it well may be you will find this in the service manual in the electrical diagram section.
The following user(s) said Thank You: Louisd9
03 Apr 2020 15:24 #220631 by DrRobin
Replied by DrRobin on topic Wire colours for the radio
I replaced the radio in my 2011 Jimny with an aftermarket radio, it came with an adapter, but one of the wires was in the wrong place, the lights wire I think, but it might have been ACC.
I must have found a wiring diagram as I traced it through and corrected the lights position. I aslo added rear speakers so must have traced those as well, but can't find the wiring diagram now.
For what it is worth here is the radio DIN connector assignments.
A quick look online and these pin outs don't seem to match other 20 pin plugs, not sure how that works then? I can try and find my wiring diagram or check the colours over the weekend if you want?
  • Louisd9
03 Apr 2020 16:12 #220635 by Louisd9
Replied by Louisd9 on topic Wire colours for the radio
Thank you very much! I found a small coloured diagram.. I think I figured it out thank you very much!
03 Apr 2020 16:32 #220639 by Dunders
Replied by Dunders on topic Wire colours for the radio
ISO adapter is plug and play and costs a few quid - no need to match/solder at all.
04 Apr 2020 18:55 #220699 by RainerK
Replied by RainerK on topic Wire colours for the radio
There are also ISO plugs that can be used on the original wires. With them there are a little less wires behind the radio and maybe a little less chance for rattling.
Time to create page: 2.233 seconds
