How to cut fenders
- Olliecarr25
14 Mar 2020 09:25 #219853
by Olliecarr25
How to cut fenders was created by Olliecarr25
Hi there just brought a set of insa turbo special tracks and might need to cut the fenders and was wandering what’s the best way to do it and how do u re attach the wheel arch liner once u have cut them thanks
- Thank you received: 1999
14 Mar 2020 09:36 #219855
Replied by Lambert on topic How to cut fenders
I would suggest that it is going to be a fairly custom process and you will need to make it up as you go along, taking the minimum amount in little sections at a time. It will probably be easier to support the car on the chassis and remove the road springs to obtain maximum compression more safely and just see what keeps catching. How big are the tyres?
14 Mar 2020 11:56 #219856
by Keithy
Replied by Keithy on topic How to cut fenders
Never seen the arch liners re-attached as the part they go to is the part trimmed off.
The vertical seam on the front bulkhead needs to be folded out of the way at the lower portion.
14 Mar 2020 20:41 #219865
by Scimike
Replied by Scimike on topic How to cut fenders
Do the fenderless amongst us apply any extra protection under the wings, when I looked last it just appeared to be finished in what I assume is a phosphate primer?
The comment about removing the arch liners made me think back to my Hillman Avenger days and the eternal mud trap that was the top wing section. It rotted out quickly, as did the rest of the car, but was a primary hole / filler hot spot on the vehicle.
Is the modern primer good enough on its own or do you recommend extra protection?
Mike
Mike
- Max Headroom
- Banned
- Thank you received: 217
14 Mar 2020 22:54 #219871
by Max Headroom
Replied by Max Headroom on topic How to cut fenders
Wait - what? Am I missing something here?
Guitars - shouldnt this topic be in the 'Lounge' section?
15 Mar 2020 12:39 #219886
by Keithy
The following user(s) said Thank You: Scimike
Time to create page: 0.230 seconds
