Experience with ISOFIX child seats in Jimnys 3
11 Mar 2020 09:16 - 11 Mar 2020 09:21 #219716
by Bosanek
Experience with ISOFIX child seats in Jimnys 3 was created by Bosanek
Does anyone have experience with using ISOFIX child seats in Jimnys 3 which have ISOFIX rear seats? Such Jimnys were produced from 2012/2013 to the end of production in 2018.
Mine has ISOFIX mounting points. There are two metal anchors (welded to the floor) under the upper part of each rear seat, and there is a single anchor in the rear side of each rear seat.
I have unsuccessfully tried to install an ISOFIX base of an ISOFIX-compatible child seat (category 0+).
The problem was that the rods in the base, which are supposed to go under the upper part of the seat and attach to the floor anchors, are not nearly long enough. The base hits the upper part of the seat long before the rods reach the floor anchors below the upper part of the seat.
See the attached pictures. Picture 2 shows the unsuccessfull attempt, and the floor anchor is slightly visible between the upper and lower parts of the seat.
I thought that any ISOFIX child seat should be compatible with any ISOFIX car seat. Has anyone had issues with this length and how to resolve them?
Last edit: 11 Mar 2020 09:21 by Bosanek.
- CC Baxter
11 Mar 2020 09:45 #219717
by CC Baxter
Replied by CC Baxter on topic Experience with ISOFIX child seats in Jimnys 3
The child seat makers normally have a good customer service department.
Why not send your pictures to them, they may be aware of the issue and supply extension arms. It's not really something you want to get imaginative with.
Chris
Chris
- Thank you received: 1970
11 Mar 2020 09:47 #219718
Replied by Lambert on topic Experience with ISOFIX child seats in Jimnys 3
Not having either children or the need of car seats in our 2016 I wouldn't know. Is the backrest adjustment angled sufficiently far to allow the seat to clear?
- GeezerDan
11 Mar 2020 09:47 #219719
by GeezerDan
Replied by GeezerDan on topic Experience with ISOFIX child seats in Jimnys 3
On all the isofix bases I've had the 'rods' normally extend by using the slide button on the side of each one. Then once they attach to the isofix anchors, they click and lock in place each time you push the base towards the back of the seat. Not sure if that's any help.
- Max Headroom
- Banned
- Thank you received: 217
11 Mar 2020 22:32 - 11 Mar 2020 22:42 #219743
by Max Headroom
Replied by Max Headroom on topic Experience with ISOFIX child seats in Jimnys 3
Geezer Dan is right.
The arms on the child's seat should fully extended first. There should be a release lever somewhere on the child's seat to allow those arms to extend,
Once extended, you then push the arms onto the anchors ensuring you get a positive "Click" as they lock,
Try to sharply pull the seat off the anchors to test that they have locked properly. (There should also be a green colour indicator showing that it is locked) but I always did a physical check too.
Then when satisfied that its locked, push the seat firmly rearwards, this shortens the arms - they're on a ratchet. It's that ratchet that needs to be released to extend the arms.
There's a section in this video covering Isofix fitting HERE
(The video shows two yellow 'cup's being fitted over the anchor points - these help by pushing the seat fabric out of the way, and also protect the seat fabric from wear/damage when pushing the arms onto the anchor points. They're removeable but I used to leave them in so you can easily see where the anchor points are next time you fit the child's seat)
Hope this all makes sense
Last edit: 11 Mar 2020 22:42 by Max Headroom.
13 Mar 2020 09:46 #219811
by Bosanek
Replied by Bosanek on topic Experience with ISOFIX child seats in Jimnys 3
Thank you all very much for the help.
The child seat which I tried does not have telescopic (extensible) mounting rods to attach to the floor isofix anchors (I double checked and really tried to extend them). I contacted the manufacturer and got a written confirmation that the product is not compatible with Jimnys.
A couple of friends who have children looked at the attached pictures and commented that the rods on that product are so short that they doubt it could be installed in their vehicles as well.
I learned in the meantime that the isofix standard does not guarantee a product vs. vehicle compatibility. It only defines certain aspects of attachment methods and leaves the specifics to vehicle and seat manufacturers.. Therefore vehicle vs. product compatibility should always be determined on an individual case (combination) basis.
Does anyone have confirmed experience with a certain isofix child seat in an isofix equipped Jimny 3?
Time to create page: 0.450 seconds
