jimny smells hot
01 Mar 2020 21:55 #219260 by mag
jimny smells hot was created by mag
anyone had this , jomny runs fine but when laning at low speed or doing 65-70 on motorway , smells hot , temp gauge reads fine , levels all ok and it doesn`t overheat , just smells hot and feels warm under bonnet ???
01 Mar 2020 23:03 #219262 by Busta
Replied by Busta on topic jimny smells hot
It's normally all the mud from the lanes getting baked onto the exhaust. It's normal for it to feel warm under the bonnet- there is an engine in there!
The following user(s) said Thank You: mag
02 Mar 2020 05:25 #219265 by Lambert
Replied by Lambert on topic jimny smells hot
Mine tends to smell warm when I have had one of the big for it trailers up some of the hills round here but as Busta says it's got an engine under the bonnet and it's having to work quite hard.
02 Mar 2020 09:08 - 02 Mar 2020 09:08 #219272 by mag
Replied by mag on topic jimny smells hot
so probably normal then , just never noticed it so much on my other 2 jimnys I`ve had
Last edit: 02 Mar 2020 09:08 by mag.
  • Daniel30
02 Mar 2020 10:46 #219280 by Daniel30
Replied by Daniel30 on topic jimny smells hot
As Busta mentioned the roads are so full of water and muck at the moment more than likely all that baking on
  • muto
03 Mar 2020 18:20 #219335 by muto
Replied by muto on topic jimny smells hot
Check that there is no oil dripping to catalysator. even very small amounts will smell like you mentioned. For some reason my car does this if it is parked not straight for a weekend. Seems that some drops of gear oil finds it's way to exhaust. The leak is very small, i check the level every year but does not need refilling. Some links on top of the gearbox are quite oily. Anyone know exact place where it is leaking?
Time to create page: 0.614 seconds
