Sound and corrosion proofing.
25 Feb 2020 07:18 #219045
Replied by Soeley on topic Sound and corrosion proofing.
Hello and welcome, I got a new Gen4 last January and had it treated with Dinatrol within the first two months.
- CC Baxter
25 Feb 2020 08:49 #219047
by CC Baxter
Replied by CC Baxter on topic Sound and corrosion proofing.
"I doubt I would bother and instead would save the money towards another Jimny in the future". There's a comment I fully appreciate, I look older everyday so why shouldn't the car?
Chris
Chris
- Thank you received: 1866
25 Feb 2020 09:36 #219048
Replied by Lambert on topic Sound and corrosion proofing.
Given my proposed indefinite ownership period, that my car is 9 years old but is in as good condition as some at 4 years old makes lots of sense to me. It's been worth the effort.
- CC Baxter
25 Feb 2020 10:30 #219049
by CC Baxter
I've been using Waxoil since 1982 (new SJ410) and like it for the very reason it's not permanent. Out of the way service items are much easier to tackle when you can easily rub off the cack. I'm not endorsing doing nothing, just give some serious thought to what you do. Expensive body treatments do not buy piece of mind, they just transfer your worry elsewhere.
Chris
Chris
- GeezerDan
25 Feb 2020 12:36 #219050
by GeezerDan
Replied by GeezerDan on topic Sound and corrosion proofing.
Where did you get it treated @Soeley and how long should it last before checking/re-applying?
- Roger Fairclough
Topic Author
- Thank you received: 211
25 Feb 2020 17:45 #219058
by Roger Fairclough
Replied by Roger Fairclough on topic Sound and corrosion proofing.
Cheers guys, I appreciate your comments. I emailed Suzuki with the question about corrosion resistance and they have replied as follows:-
Thank-you for your recent e-mail to Suzuki Customer Services regarding the Suzuki Jimny.
I have liaised with our Technical Department regarding your query; they have advised me that the current Suzuki Jimny does has a rust proof treatment applied.
Steel sheets are given corrosion resistance on the interior / and or exterior. These corrosion resistance steel sheet materials are called one of two-side galvanized steel sheets.
It is for the sake of rust protection that these materials are selected and given a variety of treatments as described below:
1. Steel sheets are treated with cathodic electro primer which is excellent in corrosion resistance.
2. Rust proof coatings are applied to door and side sill insides where moisture is liable to stay.
3. Vinyl coating is applied to body underside and wheel housing inside.
4. Sealer is applied to door hem, engine compartment steel sheet-to-steel sheet joint, and the like portions to prevent water penetration and resulting in rust occurrence.
I hope this is helpful to you, however if you have any further queries please do not hesitate to contact us on 08085 011959.
So there you have it, right from the horses mouth. Based on the comments from Suzuki I don't see the need to add anything to what is already there but thanks anyway for your comments.
Roger
Roger
Time to create page: 0.374 seconds
