LED Headlights
- Grima
21 Feb 2020 19:25 #218841
by Grima
Replied by Grima on topic LED Headlights
I thought the self adjusting headlight thing? was near the back axel (adjusts to weight in rear) maybe you can do it there. You seem to have a gift for this sort of job.
21 Feb 2020 20:43 #218850
Replied by Soeley on topic LED Headlights
The rear axle adjuster is just to compensate for various weight loads in the rear. You still have to set the correct datum which is achieved with the actual headlight adjusters.
- Grima
21 Feb 2020 20:58 #218853
by Grima
That's my point, if Suzuki dealers setting is to high & you keep getting flashed it must be easier to fool the car so that it thinks it has weight in back. So it lowers the head lights rather than pissing about with a screwdriver behind the head lights.
21 Feb 2020 21:42 #218856
It is just a fixed bar from the axle to the sensor. If it was like an adjustable tie-rod then yes maybe, but the headlight adjusters are not that hard to reach.
- Grima
21 Feb 2020 21:56 #218858
by Grima
just a thought as lift kits supply a bracket to correct the head light setting, so something should move up or down.
- Thank you received: 228
12 Mar 2020 23:23 #219801
by 300bhpton
Replied by 300bhpton on topic LED Headlights
Thought I'd feedback. I took my Jimny to the dealer and got the headlights alignment checked. They were out. Seems headlight alignment isn't part of the normal checks when a new vehicle leaves the dealership and is often done prior to arriving at the dealers.
Either way, it seemed to have slipped the net. With others saying they are being flashed, I would urge you to get them checked. Since having mine done I have not been flashed at all. And have done a fair bit of night driving.
The following user(s) said Thank You: Gadget
