Bonnet S
23 Jan 2020 05:17 #217571 by Lambert
Replied by Lambert on topic Bonnet S
Daniel30 wrote: you pimping your badge Lambert?? :whistle:
Yeah. Something to do with hating chrome on cars. The S is going to be a test piece for wrapping something intricate. If it is too fiddly then paint is the answer.
23 Jan 2020 05:20 #217572 by Lambert
I think I have something very like that in a double sided tape, once applied it's there forever. Job for the weekend.
23 Jan 2020 10:28 - 23 Jan 2020 10:33 #217584 by Max Headroom
Replied by Max Headroom on topic Bonnet S
Here you go, Lambert
Here's what it looks like when removed.
The manufacturer's glue was mostly around the edges on mine. so you will need to gently prise it off a little at a time, carefully working around it . Mine was on pretty solidly - but you may find yours is different. Looking at it closely again the glue might have been that sticky foam stuff often used for car badges - Im sure you will know what I mean by that.
Pictures showing reverse side of badge and how thin it is. No lugs on the rear - it's flat. Hope this helps
Last edit: 23 Jan 2020 10:33 by Max Headroom.
23 Jan 2020 12:03 #217589 by yakuza
Replied by yakuza on topic Bonnet S
I do not like chrome either. I just rubbed the chrome with a 3M pad and brush painted. Tapping it with the tip of the brush left no brush marks. Will do the same to the other badges some day. Or just remove them maybe.
23 Jan 2020 15:49 #217602 by Lambert
I would debadge the back door but management are against that. The other alternative is to replicate the lettering in vinyl, that way I get yellow and they still have the badges, kinda.
23 Jan 2020 18:53 - 23 Jan 2020 18:53 #217616 by Keithy
Replied by Keithy on topic Bonnet S
Lambert wrote: I would debadge the back door but management are against that.
Sack the management and buy your own Jimny...way more fun....
Last edit: 23 Jan 2020 18:53 by Keithy.
Time to create page: 0.156 seconds
