Oil light on when idling
- Olliecarr25
04 Jan 2020 16:29 #216995
by Olliecarr25
Oil light on when idling was created by Olliecarr25
Hi I have a 2002 Suzuki jimny and today the oil light started to come on when the car was idling I have just fitted a new oil pressure switch with no luck dose anyone know what the problem could be I have also done a oil and oil filter change about 100 miles ago but was fine at first thanks in advance.
- Thank you received: 1862
05 Jan 2020 05:28 #217010
Replied by Lambert on topic Oil light on when idling
The most obvious question is is the level correct and are there any leaks? After that did you use a good replacement pressure switch not a cheap one as there's increasing reports of more and more dodgy sensors coming to the market for all manufacturers.
The following user(s) said Thank You: Olliecarr25
- Olliecarr25
06 Jan 2020 20:00 #217071
by Olliecarr25
Replied by Olliecarr25 on topic Oil light on when idling
The oil level is smack on and can’t see any leaks and I got the switch from euro car parts so it should be ok?
06 Jan 2020 20:08 #217072
If you had said the switch was supplied by Martin or jimnybits I might have been inclined to think it should be ok but eurocarparts have been a bit too hit and miss in my experience. Do you still have the old one you removed.
- Olliecarr25
07 Jan 2020 10:07 #217079
by Olliecarr25
Yeah I still got the old one do u think it could be a bad connection because the engine bay got a bit mucky?
07 Jan 2020 14:31 #217082
It's worth checking out the possibility that the original switch was just in need of a bit of a clean certainly.
