Gen4 towing a caravan
20 Dec 2019 17:34 #216636 by Foxtrot
Unfortunately this video is in German, however it shows a review of the Gen4 Jimmy dragging a lightweight caravan. It would be great to know if they think it can tow it ok...:)
20 Dec 2019 17:49 #216638 by Busta
Replied by Busta on topic Gen4 towing a caravan
I've been using Gen3s for towing for 6 years now. They are good little tow cars as long as you respect the towing capacities. A gen 4 should have no problem with a caravan but you have to consider that they are a small vehicle with a short wheelbase so better suited to small caravans, regardless of the weight. Also when you take a low powered vehicle and attach a trailer to it progress can at times be slow, but that doesn't mean it can't do it!
The following user(s) said Thank You: Foxtrot
20 Dec 2019 18:04 #216640 by Foxtrot
Replied by Foxtrot on topic Gen4 towing a caravan
Busta wrote: I've been using Gen3s for towing for 6 years now. They are good little tow cars as long as you respect the towing capacities. A gen 4 should have no problem with a caravan but you have to consider that they are a small vehicle with a short wheelbase so better suited to small caravans, regardless of the weight. Also when you take a low powered vehicle and attach a trailer to it progress can at times be slow, but that doesn't mean it can't do it!
Yes your right with your towing observations, I have a small lightweight caravan weighing 900kg .My previous Gen3 struggled a bit on hills and pulling out at junctions. I would assume the Gen4 is a lot better as it has more torque and delivered at lower revs.
21 Dec 2019 03:27 #216652 by Lambert
Replied by Lambert on topic Gen4 towing a caravan
Agreed. If my gen3 is capable of towing a 1300kg twin axle sheep trailer with a load that has a habit of moving, which it has frequently for the last 9 years without any demonstrable problem except being a tad slow, then the gen4 with it's better power and torque distribution has to be as good for starters and hopefully noticeably better.
21 Dec 2019 15:04 #216673 by Busta
My old Jimmy had a Liana engine in it and that definitely helped getting up to speed. Now looking to do the same to my current one.
21 Dec 2019 18:01 #216681 by facade
Replied by facade on topic Gen4 towing a caravan
I've got a little 650kg caravan to tow, but as the towbar took until November to arrive, it will be next year before I try towing it.
Time to create page: 0.219 seconds
