Unfortunately this video is in German, however it shows a review of the Gen4 Jimmy dragging a lightweight caravan. It would be great to know if they think it can tow it ok...
I've been using Gen3s for towing for 6 years now. They are good little tow cars as long as you respect the towing capacities. A gen 4 should have no problem with a caravan but you have to consider that they are a small vehicle with a short wheelbase so better suited to small caravans, regardless of the weight. Also when you take a low powered vehicle and attach a trailer to it progress can at times be slow, but that doesn't mean it can't do it!
Busta wrote: I've been using Gen3s for towing for 6 years now. They are good little tow cars as long as you respect the towing capacities. A gen 4 should have no problem with a caravan but you have to consider that they are a small vehicle with a short wheelbase so better suited to small caravans, regardless of the weight. Also when you take a low powered vehicle and attach a trailer to it progress can at times be slow, but that doesn't mean it can't do it!
Yes your right with your towing observations, I have a small lightweight caravan weighing 900kg .My previous Gen3 struggled a bit on hills and pulling out at junctions. I would assume the Gen4 is a lot better as it has more torque and delivered at lower revs.
Agreed. If my gen3 is capable of towing a 1300kg twin axle sheep trailer with a load that has a habit of moving, which it has frequently for the last 9 years without any demonstrable problem except being a tad slow, then the gen4 with it's better power and torque distribution has to be as good for starters and hopefully noticeably better.
