Steel wheels
- Mole
10 Sep 2019 19:33 #213392
by Mole
Steel wheels was created by Mole
Evening.
I was looking at wheels and came across a company selling 15x10 steel wheels now this is probably a daft question but what tires could you run with them I know how to work out the OD of a tire but not sure what to search for the bead width to fit the wheel and where you'd start looking for them obv wouldn't want the bead of the tire to stick out past the tread
- Thank you received: 705
10 Sep 2019 22:32 #213404
Replied by jackonlyjack on topic Steel wheels
31 x 10.50 x 15
265/75/16 up to 285/75
The following user(s) said Thank You: Mole
11 Sep 2019 17:49 #213416
Replied by Riccy on topic Steel wheels
15x7 is the max you can fit with 0 offset. I have 15x8's and they need about a 10mm spacer. 30mm spacers are the smallest available, so I have those. If I had known about it I would have bought -15 or -30 offset rims. This can be applied to the 15x10 size with offset also.
- Mole
12 Sep 2019 15:09 #213432
by Mole
Replied by Mole on topic Steel wheels
Excellent thank you
13 Sep 2019 14:42 #213478
by Bob1050
Replied by Bob1050 on topic Steel wheels
As winter approaches - any tips for a set of basic steel wheels that I could stick a set of snow tyres onto? A wheel rim that would bolt straight onto a new Gen 4 Jimny with zero fitting/clearance problems.
- Thank you received: 1926
13 Sep 2019 15:19 #213481
Replied by Lambert on topic Steel wheels
As in from another vehicle? None. Jimnybits sell sets in various sizes and offsets.
Time to create page: 0.178 seconds
