Could someone help me? Wheel spacer on ebay..
- Thank you received: 504
a bit costly this, but will save some work..
Item on ebay 85$
freight 50$
tax to norway 25% 37$
sum approximately twice the ebay listing price..
Got a tracking number and all. Will come back with an update and product test later. Should have it here in two weeks.
If it wasn't for the Norwegian 25% VAT on everything I would buy a bunch and sell in Europe...
Riccy wrote: Ive tried contacting them as well, as I also am interested in a pair of these.
Ebay gives this message when I try:
"We couldn't find an answer. Unfortunately, this seller isn't able to respond to your question. We suggest reviewing the item again to see if your answer is in the seller's listing."
When I scroll down on their listing I see they are open 9-5 mon-fri PT. I presume PT means pacific time, which is 7 hours behind the UK. I will try again later on today incase its a time thing. No idea other than that or getting some made by a local engineering fabricator
@£65 not sure how they make a profit.....I'll play with it next week if I'm not too busy Richard.
I can make it ready finished stp, igs, dwg files, or whatever if someone wants to make it in a lathe or machining center. I just want two spacers for the design work.
Send me an iges file and I'll look into it.yakuza wrote: I have designed a one piece steel spacer of my own design. Tried to get quotes to have it made locally but just the rough numbers was around 250€ even if I found "free" material blanks..
