2007 Gear Shift Lever Removal
- doc2who
24 Jun 2019 18:33 #210275
by doc2who
2007 Gear Shift Lever Removal was created by doc2who
Hi Guys, I have a 2007 1.3ltr Jimny, I am attempting to change the clutch and I'm following the 'How to' Guide. In the guide it says 'Remove the Centre Console. We now need to remove the gearstick. To do this you should remove the rubber boot that is attached to the centre console. There is then another rubber boot underneath which needs to be raised to expose the three retaining plate bolts. Remove the three bolts and then remove the gearstick.'
On my Jimny, once I have removed the Centre Console, Rubber Boots and Lower Gaiter, the Gear Shift Lever is in a solid housing with 2 bolts, one at the front and one at the rear (as per the attached picture).
Do I just need to remove the two bolts to remove the Gear Shift Lever?
- Dano0404
25 Jun 2019 09:02 #210296
by Dano0404
Replied by Dano0404 on topic 2007 Gear Shift Lever Removal
Just undo the two bolts and it will come away
25 Jun 2019 17:05 - 25 Jun 2019 17:06 #210306
Replied by Riccy on topic 2007 Gear Shift Lever Removal
You are supposed to push down and rotate on the metal collar with the square hole around the stick (spring inside can be seen in your picture). its easy enough by hand. You will see when its out how it holds onto them two bolts
edit: there should be a plastic bushing on the end of the gearstick, be careful not to loose that
Last edit: 25 Jun 2019 17:06 by Riccy.
- doc2who
25 Jun 2019 18:21 #210308
by doc2who
Replied by doc2who on topic 2007 Gear Shift Lever Removal
Thanks Riccy,
I removed the two bolts as Dano0404 suggested and discovered that the collar could have been rotated. I have re-inserted the bolts and will rotate the metal collar when I refit it. Ihave the plastic bush on the end.
Thanks again.
Thanks again.
Time to create page: 0.164 seconds
