Finally a true Jimny Owner
20 Apr 2019 10:52 - 20 Apr 2019 10:55 #206402 by Scimike
Today it feels like I have finally become a true Jimny owner.
I have started my first kingpin rebuild and everything's going fine.
Finally joined the club :laugh:
And yes every bolt came out EXCEPT the ABS sensor bolt which just snapped... What it wrong with that bolt, made of monkey metal?
Anyway helicoil and stainless steel replacements should make it a thing of the past. May even add value to the vehicle :P
Thanks to Martin for all the new bits and the how to video
Last edit: 20 Apr 2019 10:55 by Scimike.
20 Apr 2019 12:47 #206406 by BGBrit
Replied by BGBrit on topic Finally a true Jimny Owner
Well done,,, I did my offside king a couple o' years ago, main thing I believe is not to over do the grease packing, 100 m/ltrs I think is the recommended amount by Suzuki.
  • Caelite
20 Apr 2019 13:22 #206407 by Caelite
Replied by Caelite on topic Finally a true Jimny Owner
Yeah I snapped my driverside ABS bolt, good thing is it's siezed enough that it's been sat in there for a year, I've been meaning to drill & retap it but have been lazy.
20 Apr 2019 14:58 #206413 by jackonlyjack
Yes 100ml of grease is advised
I also snapped both of the abs bolts.Drilled and tapped out, if they snap next time
i will drill out and nut and bolt them ;)
Also well done on diy replacement :)
20 Apr 2019 22:43 #206434 by Max Headroom
What size is that offending ABS bolt?
21 Apr 2019 05:30 #206437 by Lambert
Replied by Lambert on topic Finally a true Jimny Owner
M6 by about 15 to 20 mm only little.
The following user(s) said Thank You: Max Headroom
Time to create page: 0.182 seconds
