Front Accessory 12V Power Socket
- Juullees
- Juullees
You could easily run a seperate one straight from the battery through to the top of the dash yo have a female cigarette lighter socket there for your solar panel y
to trickle charge the battery.
I never had much luck with our old SJ and a solar panel.
With it being 20 minutes away I couldn't just take it for a spin like I do the Jimny now.
I ought to put the Jimny on a battery manager now but the old battery lasted 8 years with seldom usage.
MilkyRon wrote: Hi Juullees,
Welcome and congrats on the new Jimny. As has already been said, that 'front accessory power socket' will only be good for supplying power not for getting any data from your phone to the sound system.
If you want to play music from your phone through the car sound system, the only way to go is to replace the standard head unit (the CD player). Don't panic, it's not as expensive or as complicated as it may seem. There are a few posts on this forum covering the exact process. The good news is, that they come in standard sizes and all you need is the new head unit and something called an ISO wiring harness. If you don't fancy doing it yourself, somewhere like Halfords will not only sell you both but they'll fit them for you as well (for a fee).
ISO Harness example
www.halfords.com/technology/car-audio/st...ess-adaptor-ct20hd02
Head Unit example
www.halfords.com/technology/car-audio/ca...ouble-din-car-stereo
Both of these can be sourced elsewhere cheaper and there are many more options for head unit out there. Happy shopping!
The tricky bit is sourcing the right surround as they differ by a few millimetres so if you fined one you like you can get the surround afterwards once you have the correct measurements
