Electric transfer case replaced with Manual
  • Khanmalghani
14 Mar 2019 19:43 #204595 by Khanmalghani
Electric transfer case replaced with Manual was created by Khanmalghani
Hello, i need help, i changed my electronic transfer case on jimny with old manual transfer case and done some wiring from mechanic to get 4x4 working,, before this change my jimny goes On 80 on 3000rpm and touch 120kmh on 4000rpm..after this change it stuck on 70kmh on 3000rpm and touch 100kmh on 4000rpm..what can be the problem . Needed help
14 Mar 2019 20:06 #204598 by Lambert
Welcome to the forum. The problem is that the electronic transfer box is a direct 1:1 drive in high range whereas the manual transfer box is a 1.3:1 reduction in high range. There are 3 options. Live with it. Fit the older matching differentials from the donor vehicle. Or fit larger tyres specifically tyres with a diameter around 31 inches.
Time to create page: 2.221 seconds
