Jimny snow performance
  • OlaGB
04 Feb 2019 12:05 #202540 by OlaGB
Replied by OlaGB on topic Jimny snow performance
Gadget wrote:
Keithy wrote: Jimny is fine in snow......it's all the other road users you have to get around.
That's a great video!
Put good winter tires on a 86 sapphire cosworth, and you would have _no_ problems driving in those conditions in that video..
Not kidding. The only reason people struggle in those conditions, with any car, is due to no good all season tires. They are completly rubbish compared to real winter tires.
04 Feb 2019 12:44 #202541 by Busta
Replied by Busta on topic Jimny snow performance
Lambert wrote: I'm afraid I'm not with you both on this. The Jimny is a perfectly acceptable winter vehicle when fitted with suitable tyres and driven with a sense of decorum. I would further contend that if a suitably equipped Jimny is too much for some drivers then they are very likely to be having difficulty no matter what they are driving.
Perfectly acceptable, yes, and capable of being used in the very worst conditions. But not as user friendly. If somebody was asking for a suggestions of a good car for winter driving I'd always suggest permanent 4wd over selectable 4wd simply because lots of people struggle to understand when to use 4wd in a car like a Jimny. Add manual hubs into the equation and it's complicated further. Then consider that when in 2wd the Jimny's capabilities in snow are lower than a typical FWD car (assuming the same tyres), with the added complication of a tendancy to oversteer.
04 Feb 2019 13:14 - 04 Feb 2019 13:25 #202543 by Bosanek
Replied by Bosanek on topic Jimny snow performance
I have quite a bit of experience on driving a Jimny on snow (although I live far closer to the Equator than most other members on this forum :)).
For mixed on-road packed snow / wet tarmac / dry tarmac driving, a Jimny is a poor choice. Reason: part-time 4WD transmission without inter-axle differential. This means that, in such conditions, you constantly have to be careful in which transmission mode you are and to shift between 2WD and 4WD whenever the road surface changes between packed snow and somewhat dry surface.
Also, depending on tyres, on packed snow a Jimny can still be relatively unstable even in 4WD (depending on tyres, speed and driving competence). It does require some "active" driving to properly use its potential and avoid its weaknesses. When done so, it is a strong performer.
If you happen to be unable to engage 4WD for any reason, a Jimny in 2WD on packed snow is WAY worse than any ordinary 2WD FWD car, even worse than a 2WD RWD like a BMW. It can be pitiful in how trivial situations a 2WD Jimny becomes helpless on snow (example: reversing uphill).
I drove a diesel Jimny so this issue was even worse as its front-rear weight distribution is even worse.
However, on not so packed snow (and especially in somewhat deep snow) Jimny is a particularly strong performer. It will ultimately get bogged if the snow depth is above 20 cm (the light rear end begins to shake under throttle and thus jumps around and loses traction further).
Even if you get bogged in snow, it is rather (relatively) easy to get unstuck either by shoveling under it (shorter car - less snow to shovel from under it) or by pulling such a light car out with another car.
I got stuck in snow a few times in quite embarrasing situations and once a passing Fiesta 4 pulled me out and a Golf 2 did so as well on another occasion :)
You can't expect such help if you get stuck in a Grand Cherokee or in a Defender ...
Last edit: 04 Feb 2019 13:25 by Bosanek.
04 Feb 2019 15:31 #202550 by Lambert
Replied by Lambert on topic Jimny snow performance
Sorry blokes but I honestly don't recognise the vehicle you're describing as being the same as mine. The Jimny I recognise is well planted even on packed snow. Sure if you give it a foot full of go it will spin it's back tyres but so will anything else. If you are going too fast into a corner it will understeer if you stand on the brake it will slide wherever, but if you drive to the conditions it will absolutely go where you point it as much or better than any other 2wd or 4wd will.
04 Feb 2019 16:09 - 04 Feb 2019 16:09 #202552 by yakuza
Replied by yakuza on topic Jimny snow performance
Agreed Lambert.
It comes down to what tires you have, what load you have in the car, the tire pressure and of course your driving style. Where I live we are used to drive on snow. Further north even more so, and further south not so much...
Your personal experience will play a large part.
I think that all these variables is just as important as the car itself.
I follow the stock of incoming car-wrecks in a database and the beginning of winter has the most wrecks. It gets less and less during the winter.
It is the same for Jimnys as all other kinds of cars.
Last edit: 04 Feb 2019 16:09 by yakuza.
04 Feb 2019 16:13 #202554 by adrianr
Replied by adrianr on topic Jimny snow performance
We all have our own perspectives and experiences so we can all be right from where we see things.
I'm with Lambert on this one. Been very pleasantly surprised at how well these little trucks perform in all sorts of conditions including new snow and packed snow. Decent tyres are everything and an understanding of what to do and when and you would be hard pressed to get properly stuck.
