Tyre pressures
03 Feb 2019 10:18 #202429 by Lambert
Replied by Lambert on topic Tyre pressures
205 70 15 96 h. The size is less important than the load rating which is a code expressed by the 4th number in the sequence I just posted. The higher the load number the less pressure you need for the optimum performance of the tyre. An all terrain will probably be something like a 100 or 102 and will need less pressure than my road pattern. But it also depends on the weight of the specific vehicle, Ermintrude is relatively light weight and needs less air than one with winches or timber storage decks in the back etc.
  • Cremator1
03 Feb 2019 10:35 #202431 by Cremator1
Replied by Cremator1 on topic Tyre pressures
Mine are 97t and don’t carry anything in back just standard other than steel rims
03 Feb 2019 12:59 #202443 by Lambert
Then as suggested start with 22 or 23 and go from there. You're wanting it to feel smooth but not floaty. If they're too soft it will squirm an wobble over bumps and holes if they're too hard it will crash and bounce. You're wanting the happy medium.
  • Cremator1
03 Feb 2019 16:52 #202453 by Cremator1
Hi ok put 22 in them will try that also fitted a steering damper and when turning wheel at low speed you can hear it creak when turning the wheel
03 Feb 2019 17:36 #202458 by Lambert
Sounds about right.
03 Feb 2019 17:59 - 03 Feb 2019 18:00 #202462 by jackonlyjack
Replied by jackonlyjack on topic Tyre pressures
Steering damper just ignore the squeak/creak/grown noise mine makes them all :laugh:
Last edit: 03 Feb 2019 18:00 by jackonlyjack.
Time to create page: 0.310 seconds
