Gen3 coat storage
- grumyoldjoe
- Elite Member
- Thank you received: 20
27 Jan 2019 08:55 - 27 Jan 2019 08:57 #201809
by grumyoldjoe
Wine improves with age.
Replied by grumyoldjoe on topic Gen3 coat storage
I carry spare clothing in vac bags. Can get them really flat and then store behind the drivers seat or even under the folded down back seat.
Have a smaller one stored inside the seat cover back against the seat to keep in place.
Last edit: 27 Jan 2019 08:57 by grumyoldjoe.
27 Jan 2019 09:23 #201812
thin stuff, cant take much weight without deforming. Maybe a couple of light jumpers or a coat would be about it.
Soemthing which attached to the grab handles in the rear might be your best option to hang anything in there
Replied by Riccy on topic Gen3 coat storage
Lambert wrote: What is the headlining made out of? E.g. would it have enough integrity to be screwed or riveted into or would it need to be removed and have a secondary reinforcement on the back?
- Thank you received: 1876
27 Jan 2019 11:23 #201827
Replied by Lambert on topic Gen3 coat storage
Whatever I do needs to be up high to maintain as much of the load deck as possible and also to keep said coats out of the muck and corruption that is a constant presence in the back of the car. I might get the lining out and see if there is anything behind it to attach to.
27 Jan 2019 11:39 #201830
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Gen3 coat storage
What about some really strong Neodymium magnets? you can cut some holes / slots in roof lining. attach magnets to roof.
The hang the webbing from these using some small u or n shaped pieces of metal __n__ that stick to the magnets.
www.supermagnete.de/eng/block-magnets-ne...-force-kg=7.64,19.11
- TaterTot
27 Jan 2019 12:14 #201836
by TaterTot
Replied by TaterTot on topic Gen3 coat storage
I use some 10kg Neodyne on some small lamps I made to have in the car. That is 10kg force (or 98,1N), but it's not a crazy success, because of the lining. I decided to use magnets, as I didn't want to cut holes. If I have to make a hole, I would rather skip the magnet all together.
Time to create page: 0.174 seconds
