Re:2019 Jimny Australian special upgrade, or not?
  • cyberdriver
21 Jan 2019 21:10 #201387 by cyberdriver
Replied by cyberdriver on topic 2019 Jimny Australian special upgrade, or not?
You might be right, :Lambert, but I was thinking larger diameter for axle clearance and wider for float. Would you leave it stock for beach/dune/sand tracks?
22 Jan 2019 02:49 #201393 by zukebob
I mostly avoided sand but did do some beach driving and a bit of desert driving early on. Initially I had the stock tires which were equivalent to 225/75r15. Later I went with 32 X 11.5. The stock tires worked better for me in the sand.
The vehicle I had at the time was significantly heavier than the Jimny so I would defer to anyone that is using a Jimny for beach or dunes. If you don't receive a Jimny specific reply, it would probably still be good guidance.
22 Jan 2019 05:13 #201395 by Lambert
In Yorkshire there are no obvious places to sand drive so my knowledge is second hand but as I understand it sand really needs momentum as much as anything to keep you on the top and if you do sink in you need very low wheel speed to creep forward. Both these require torque which is a limited resource in a Jimny even the 1.5. I get what you mean about better float and clearance but more float means more drag needs more torque and more diameter means higher gearing needs more torque. Personally I'd be after a set of proper all terrain tyres in stock size and preserve what torque there is.
22 Jan 2019 05:22 - 22 Jan 2019 14:16 #201396 by Lambert
Also have a look at Ronny Dahl on YouTube he is based in West Aus and seems quite knowledgeable about sand driving, quite a big back catalogue though and I haven't seen a comparison of his for this specific case but there's bound to be some good information there.
Last edit: 22 Jan 2019 14:16 by Lambert.
  • mikeyw85
22 Jan 2019 10:08 #201400 by mikeyw85
Replied by mikeyw85 on topic 2019 Jimny Australian special upgrade, or not?
Does it require the lift to fit those tyres?
22 Jan 2019 10:33 - 22 Jan 2019 10:34 #201403 by Lambert
With the 235 its a 6pc increase in height or approximately 50mm ish plus an extra 40mm width. I'd be surprised if they didn't catch somewhere on full lock full compression?
Last edit: 22 Jan 2019 10:34 by Lambert.
Time to create page: 0.164 seconds
