Jimny gear ratio
- RaggiJimny
16 Jan 2019 11:04 #200867
by RaggiJimny
Jimny gear ratio was created by RaggiJimny
Hi,
I am buildin a jimny with 35" tires but I'm not shure wat gear ratio to use is there anyone that is familiar with the best gear ratio for 35" tires on a jimny?
Thanks
Thanks
- Thank you received: 1870
16 Jan 2019 11:33 #200868
Replied by Lambert on topic Jimny gear ratio
Have a read through the thread by holmar one of our Icelandic contributors I think his is on 35s.
16 Jan 2019 11:36 #200869
16 Jan 2019 18:13 #200900
Replied by Riccy on topic Jimny gear ratio
Gear ratios need to be calculated (use grimjeeper website and ratio info from the wiki).
To get 35" under there will require serious lifting and chopping if its going to steer and stop/go. chassis modification of body mounts will be needed also. I think Holmar uses toyota axles for extra width. Jimny axles would be unlikley to cope for long with that size tyre :laugh:
Time to create page: 1.862 seconds
