2019 spare wheel size?
12 Jan 2019 12:48 #200571
by Hanslow
2019 spare wheel size? was created by Hanslow
Would any of the owners of the new 2019 model be kind enough to measure the overall diameter and depth of the spare wheel mounted on the back? I'm looking to source a flexible wheel cover in time for my new car's arrival but hard to know if the aftermarket options will fit. Thanks.
- mikeyw85
12 Jan 2019 15:32 - 12 Jan 2019 15:35 #200580
by mikeyw85
Replied by mikeyw85 on topic 2019 spare wheel size?
I will try measure later today if i remember.
Roughly though it's a 15" rim, or 38cm.
The tyres are 19.5cm wide with 80 profile. So 19.5 x 0.80 = 15.6.
Diameter should be 38+15.6+15.6 = 69.2cm
Width is obviously 19.5cm
So it's likely you'll need a cover about 70cm x 20cm or so.
Last edit: 12 Jan 2019 15:35 by mikeyw85.
12 Jan 2019 15:32 #200581
Replied by Soeley on topic 2019 spare wheel size?
I believe it is supposed to be a full size spare. I'll measure on Tuesday if no one has done so by then.
12 Jan 2019 16:09 #200590
Replied by Riccy on topic 2019 spare wheel size?
195/80 r15 is 195mm wide by 693mm high...
tiresize.com/tyre-size-calculator/
though allow for some variances with different manufacturers.
12 Jan 2019 23:18 #200610
by Hanslow
Replied by Hanslow on topic 2019 spare wheel size?
Doh! I never even thought to work it out from the specs, thanks. Even if it's slightly different I can't see it being that far out.
- wigit
15 Jan 2019 14:09 #200792
by wigit
Replied by wigit on topic 2019 spare wheel size?
I messaged my dealer today about OEM steel wheels and got the following back
Steel wheel £96.77+ each
TPMS valve £60.39+ each
Not had a good look at the valves when I drove it, think the steelies may wait a while
Time to create page: 1.854 seconds
