Undampend tyre bounce
02 Jan 2019 09:49 #199883
by Busta
Replied by Busta on topic Undampend tyre bounce
Have a play with tyre pressures and compression rates if you have adjustable dampers. It sounds like a very subtle change. I very much doubt the properties of the tyre have changed significantly as they wear down. Swapping fronts to rear might be a worthwhile control measure.
Also, don't assume that stiffer=better. You may find that lower pressures or damping rates are needed. There's always a temptation to stiffen things up in the search for performance, which often means you completely overload another part of the chassis.
- Thank you received: 1869
02 Jan 2019 09:50 #199884
Replied by Lambert on topic Undampend tyre bounce
Km3 don't currently come small enough and km2 being a handful in the wet isn't encouraging.
02 Jan 2019 09:56 #199885
by sniper
Replied by sniper on topic Undampend tyre bounce
Next Wednesday at 1pm is good for me. I'll PM my phone number.
Can you confirm meet at, my co driver confuses me if I ask it to do anything other than go to a post code...
sniper
sniper
02 Jan 2019 10:03 #199886
The trailmaster aren't adjustable mores the pity and using the formula for working back the exact tyre pressure from the maximum load at x pressure on the side of the tyres 23 front and 26 rear is allegedly spot on. There's definitely something that has settled in the tyre wall though because Zebedee has the same tyres at the same pressure but 2 years newer with a quarter of the mileage and those tyres don't have anything like the bulge in the loaded bit of the side wall.
02 Jan 2019 10:57 #199890
All bets might be off. Just spotted that the sexiest tyre ever made is available in 215 75, kl71s come to daddy!
02 Jan 2019 11:55 #199891
by sniper
The Kumho was a serious contender when I was considering tyres.
Very well reviewed but if I remember, wear rate was quite high. That and familiarity with the old BFG AT swayed me.
sniper
sniper
Time to create page: 1.369 seconds
