May need a new exhaust, the second CAT has gone, any recommendations
01 Jan 2019 13:44 #199822 by Scimike
Just had a quick pre MOT check of my Jimny and noticed that the second CAT downpipe weld has failed, resulting in a sliding joint !
So it looks like I nedd to replace this middle section including the CAT. Seen them on ebay etc, will phone around tomorrow, but anyone got any experience of the quality of replacement parts for this section?
Any avoids or recommendations?
The good news is the rest looks perfect and I will still have to go (booked for the 4th) and hope they dont spot it.
01 Jan 2019 15:01 #199826 by jackonlyjack
No eBay APP ID and/or Cert ID defined in Kunena configurationDon't think you will find one cheaper
01 Jan 2019 15:03 #199827 by Delux
The cheaper the parts the more time you may need to spend 'tailoring' them to fit!
Although I bought a rear exhaust section for my last Jimny off ebay, searched 'Jimny rear exhaust', selected 'Price, lowest P&P' and bought the cheapest.
I figured I have all the hardware available to 'make' it fit. Imagine my surprise when it turned up, supplied with new bolts, nuts, gaskets and rubbers. Fitted perfectly!
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
01 Jan 2019 15:09 #199828 by Busta
Best to weld it up if you can. I fitted a cheap (£80?) cat and it wouldn't go through the emissions test, then the cat broke up shortly after so I knocked the ceramic out of it and ran it like that until the next MOT when I repaired and refitted the original cat. Genuine parts are expensive. I think I've welded both side of mine back on now but it's got another 20,000 miles life out of it and counting, so well worth doing.
  • paradox1001
01 Jan 2019 15:39 #199831 by paradox1001
I’ve fitted a centre cat section and rear box to mine both from eBay.
They fitted perfectly fine and it passed the emissions test no problem.
The only problem I had was the rear exhaust box was slightly larger than the original so it knocked on the towbar bracket occasionally
I used a piece of old rubber fuel pipe and a cable tie to act as a buffer and it’s been fine since.
01 Jan 2019 15:51 - 01 Jan 2019 19:34 #199832 by gv42
i had stainless steel new exhaut and a sports cat for the jimny ,, it was £290, from HIB-exhaut in ANGLESEY , a magnaflow cat,, and next is a s.s, manifold,
Last edit: 01 Jan 2019 19:34 by gv42.
Time to create page: 0.169 seconds
