Gear box oil
  • Cremator1
21 Nov 2018 18:30 #197939 by Cremator1
Gear box oil was created by Cremator1
Hi all so got my new jimny and want to change auto gear box oil and the diff oils when refilling them both do you just wait for the oil to dribble out of the filler plug hole many thanks dawn
21 Nov 2018 19:02 #197942 by Riccy
Replied by Riccy on topic Gear box oil
Yep thats it. Make sure you check you can actually undo the filler plug before you drain anything though (bin there, done that :angry: )
The fluids needed are in the wiki ;-)
  • Cremator1
21 Nov 2018 19:04 - 21 Nov 2018 19:07 #197943 by Cremator1
Replied by Cremator1 on topic Gear box oil
That’s great thank you I will have a look to see what oils I need I guess the auto box oil is different to the diff oils can’t seem to find the oils where you said
Last edit: 21 Nov 2018 19:07 by Cremator1. Reason: Missed somethink
  • Cremator1
21 Nov 2018 19:41 - 21 Nov 2018 19:42 #197948 by Cremator1
Ah ok found the oils not sure which engine I have it’s 2013 auto
Last edit: 21 Nov 2018 19:42 by Cremator1.
21 Nov 2018 19:46 #197950 by jackonlyjack
Replied by jackonlyjack on topic Gear box oil
Cremator1 wrote: Ah ok found the oils not sure which engine I have it’s 2013 auto
M13A VVT Petrol
unless you have a diesel ?
Time to create page: 1.859 seconds
