confused about hubs
- mickt
30 Oct 2018 20:46 #197188
by mickt
Replied by mickt on topic confused about hubs
Oops seems I did not know how also!! I do know though!
- macclad
30 Oct 2018 21:37 #197189
by macclad
Replied by macclad on topic confused about hubs
Thanks busta, but this is where i'm confused, if i have manual locking hubs, therfore doing away with the vacuum actuated stuff, locking the hubs on the wheels isn't anywhere near the transfer box so what sends a message to the transfer box to drive tthe front wheels, and is it a vacuum switch that sends a message to the transfer box to select low range, so i couldn't do that if iv'e disconnected the vaccums.
- TomDK
31 Oct 2018 01:20 #197190
by TomDK
Replied by TomDK on topic confused about hubs
Selecting 4wd high ratio simply engages drive to the front axle via the prop shaft. In 2wd only the rear prop shaft is engaged. In 4wd both prop shafts spins.
- Thank you received: 226
31 Oct 2018 02:27 - 31 Oct 2018 02:30 #197191
by zukebob
Reading between the lines, I am assuming you have a push-button transfer. If that is the case, when the system "sees" a vacuum (whether you have vacuum operated hubs or not), a signal is sent to the 4WD controller allowing engagement of 4WD H when the button is pushed. It also allows progression to 4WD L. To operate the transfer case when you have manual hubs with a push-button transfer, you will need to either plug the vacuum lines (so that the system really does have vacuum) or short the vacuum switch (so that the system thinks it has vacuum).
Replied by zukebob on topic confused about hubs
macclad wrote: if i have manual locking hubs, therfore doing away with the vacuum actuated stuff, locking the hubs on the wheels isn't anywhere near the transfer box so what sends a message to the transfer box
Last edit: 31 Oct 2018 02:30 by zukebob.
31 Oct 2018 08:07 #197193
by sniper
Replied by sniper on topic confused about hubs
White two wire plug that is below the battery attached to a small cylindrical reservoir with a mushroom like breather on the top, all the vacuum lines go into it. Unplug and bridge the wires on the plug, that gets the vacuum signal constant and gives the transfer box interlock signal.
Next is the vacuum line, blue one way valve from inlet manifold, again connected to the reservoir below the battery on the same side of the engine. Remove the hose from the top of the blue one way valve and block it on the manifold side. This is to stop any vacuum leak causing the engine to run poorly.
I recently fitted manual hubs and the above took five minutes. There is a pictorial guide in the wiki pages, sorry I don't know how to do a link......
sniper
sniper
31 Oct 2018 10:34 #197196
by Busta
Replied by Busta on topic confused about hubs
Thanks sniper.
Macclad- to engage 4wd both the hubs must be locked/engaged and the transfer case needs to be put into 4wd. Some choose to leave the hubs in the locked position, in which case 2wd and 4wd are simply selected using the stick or buttons as normal.
By fitting manual hubs you have made all vacuum systems redundant.
Time to create page: 2.122 seconds
