Head Gasket
  • mresowik
26 Oct 2018 20:20 - 26 Oct 2018 20:22 #197094 by mresowik
Head Gasket was created by mresowik
Hi everyone,
Got my 03 Jimny last week and loving it, having done 95K miles and there not being really any service history I have been doing a general fluid change for the entire car. I plan on taking it down to France for the winter season and am keen to change the head gasket before I go, it’s not showing any signs of being blown but for peace of mind and for future ownership I want to know it’s good and won’t potentially blow. I have some experience with bits and bobs but don’t have the tools or experience to change one on the M13A with the chain drive. Garage costs are looking to be £350 plus the gasket at £80. Does anyone on here know anywhere that could do it reasonably or themselves has the tools and would be keen to lend a hand, I’m based down in ALTON Hampshire but would be willing to travel some distance to get this done.
Second question, there is a sheared rocker cover bolt on my engine and the remaining bolt sits below the top of the shoulder, it’s the back right and really hard to get above. Does anyone know if you can replace the threaded stud in the cylinder head or is the only option to drill it out and re tap the hole. In my efforts to remove it have kind of mashed up the thread above it.
Sorry for long post, but thanks for any of your responses!
Cheers!
Last edit: 26 Oct 2018 20:22 by mresowik.
26 Oct 2018 20:27 #197095 by gv42
Replied by gv42 on topic Head Gasket
blue is the best,,,
  • mresowik
26 Oct 2018 20:31 #197096 by mresowik
Replied by mresowik on topic Head Gasket
Certainly Is a great colour
27 Oct 2018 05:49 #197098 by Lambert
Replied by Lambert on topic Head Gasket
Quite honestly there is no real reason to change the head gasket preventatively on a Jimny. I have only heard of maybe half a dozen having issues, it's not a regular problem with them. I would save the money.
27 Oct 2018 12:01 - 27 Oct 2018 12:07 #197100 by Max Headroom
Replied by Max Headroom on topic Head Gasket
Although I don't know the Jimny all that well (yet) I would wholeheartedly agree with Lambert on the matter of the headgasket, and would say that most modern car engines wouldnt require this..
Regarding the broken stud/bolt, I would be inclined to repeatedly soak it with the likes of WD40 for a few days - or lots longer if its looking grim.
Once that's done thoroughly, I'd then drill into it and try extracting it using a Dormer extractor
or another good quality extractor. (I find the likes of Draper ones with a spiral on them pretty poor in comparison to the Dormer and likely to snap.
(Bear in mind if it does snap, you will now have a hardened metal stuck inside the bolt/stud and it will need to be carefully ground using a small diamond encrusted rotary file)
I've used Dormer extractors for years with great success. You do feel them twisting slightly as you use them so be careful - if you feel that happening you are getting fairly close to breaking it.
My technique is make the largest possible hole without getting too close to the threads, drill into the end of the broken bolt/screw/stud as squarely as possible, and deep enough that the extractor cannot bottom-out in the hole.
Position the extractor squarely into the hole and firmly tap it down using a hammer until you feel the helix on the extractor start biting into the sides of the hole... Then a few more taps to make certain.
Ideally, use a T-handle from a tapping set on the square top of the extrector, slowly unscrew the bolt, applying steadily increasing pressure to the turning action on the extractor and the offending fastener will hopefully come out.
With seriously awkward ones where the extractor is slipping in the hole and not biting into the sides, I get someone to firmly tap the top of the extractor while I turn the bolt.
At a push you could use an adjustable spanner on the square of the extractor but be careful to apply only rotational force and not lean it over as you turn which could lead to breaking the extractor.
Oh yes, and dont forget: Righty Tighty, Lefty Loosey :whistle: :lol:
Last edit: 27 Oct 2018 12:07 by Max Headroom.
27 Oct 2018 13:56 #197104 by Scimike
Replied by Scimike on topic Head Gasket
Just adding a third "dont change the head gasket". As stated unless you have reason to believe its leaking I would leave it well alone. If you feel the need to change anything the top and bottom radiator hoses can deteriorate with age and usually leak first. This is not Jimny specific problem, just a car in general issue. Having said that my Jimny top hose started to leak at 50k miles (2009), but a new hose and antifreeze soo sorted it out. Supprised how weak the original top hose was compared to the new, so happy I changed it.
Time to create page: 0.373 seconds
