Jimny Heating and other camping gear
05 Oct 2018 06:10 #196509 by yakuza
Busta wrote: I wonder if there is a way you can use the existing cabin fan and heater matrix, and add an auxillary water heater in the engine bay? That way you remove the issues with condensation, and save a lot of space. You would however need some kind of water heater, a small pump and an auxillary battery to run it.
That is how my Webasto works in the VW T5. It is even connected to the CanBus.
The Webasto runs on diesel and an aux battery, and warms the water in the engine and circulate it.
It ends up in the cars heater and the fan inside starts. Great system! But a bit overkill with a such a webasto in the Jimny :)
Clothing is of course an alternative and a good one. But i would like it more cosy and comfy :)
I can just start the engine when i am awake i guess.
Lambert: I have always looked at the 12v ceramic heaters as more or less a hoax. They actually heat? :)
Scimike: Does it have to be placed inside the cabin or can it be placed under the car and run the heat tubes thru the floor?
05 Oct 2018 14:18 - 05 Oct 2018 14:23 #196517 by Scimike
Mine (on caravan) is external and the hot air is ducted inside via tubes. I have a combination of silicon tube and plastic drain pipe to duct the air, my mates is inside his Series Land rover. Only the thermostat / controller is inside the caravan.
Mine is protected by an aluminium box to keey the rain away from it.
Last edit: 05 Oct 2018 14:23 by Scimike.
Time to create page: 0.135 seconds
