Trouble with vitmods spring spacers
21 Sep 2018 13:07 #196175 by Jefferies
Anybody else had trouble with vitmods spring spacers? They just don't seem to fit properly in any configuration. I must be missing something
21 Sep 2018 14:54 #196177 by Jefferies
You can see the spacers aren't even 2" to begin with, but that's not a biggy.
The issue is that the spacer won't fit up over the rubber sleeve that sits around the cone in the middle of the spring.
Also if you remove the rubber sleeve and push the spacer up as far ad it goes then it bottoms put but fits so badly and is really sloppy it can't be the way it's intended.
21 Sep 2018 15:14 #196180 by Lambert
I thought they went under the spring on the axle end?
21 Sep 2018 15:18 #196181 by jackonlyjack
Get in touch with Darrell and ask for advice
I run his lift springs and fit well
I have seen somewhere before people having problems fitting said spacers I also think you get what you pay for
Bits4vits/Zook bob does the best one's on the market
IMO with propper R&D but not cheap
Hope you get it sorted
Jack
24 Sep 2018 13:08 #196240 by Jefferies
Right, I spoke to Vitmods and apparently that's how they are intended. I wasn't happy to fit something that fitted so badly so i've sent them back and i'm going to look elsewhere. Can anybody recommend spring spacers that they have actually tried personally and can categorically say fit/work well? Either that or i'll spend the extra ~£30 and get 2" longer springs
24 Sep 2018 13:34 #196243 by X8GGY
No eBay APP ID and/or Cert ID defined in Kunena configurationThese are mine (Bits4Vits / ZookBOB) now sold directly from the manufacturer -
Time to create page: 0.150 seconds
