Oil leak
- robkey
19 Sep 2018 12:42 #196123
by robkey
Oil leak was created by robkey
- robkey
19 Sep 2018 12:55 #196124
by robkey
Replied by robkey on topic Oil leak
it seems to be from the trans end of the rear shaft any ideas to wot seal i need to replace guys
- Thank you received: 1983
20 Sep 2018 04:25 #196142
There's a silly design flaw with the early push button propshaft where a hole allows the oil out. Have a search on here as it's a fairly easy fix.
20 Sep 2018 06:27 - 20 Sep 2018 06:31 #196144
This picture is the rear prop shaft isn't it?
The shaft seal under the transfer box output flange i guess. Should be most wet on the transfer box by the flange if so.
The oil drops fly around at speed making everything aft of the leak look like a disaster.
Mine leaks a bit btw as mine is a 2005. later 2009-10 or so got a new design.
Tried to seal it with silicone but not a complete success..
I just refill for now while looking for a new(er) shaft.
I thought that was the intermediate shaft between the gearbox and the transfer box, letting the Gearbox oil out?Lambert wrote: There's a silly design flaw with the early push button propshaft where a hole allows the oil out. Have a search on here as it's a fairly easy fix.
Last edit: 20 Sep 2018 06:31 by yakuza.
- robkey
20 Sep 2018 15:24 #196155
by robkey
so is it nothing to worry about ? check it today in work no oil from seal on trans box just from the rubber on the prop is there a way to get in it and is it just old grease not oil ?
21 Sep 2018 04:33 #196167
Sorry my bad I hadn't realised it was the that propshaft.
