Oil leak
  • robkey
19 Sep 2018 12:42 #196123 by robkey
Oil leak was created by robkey
Hi guys new to jimny driving , got home and had a burning oil smell looked under car and found a leak
  • robkey
19 Sep 2018 12:55 #196124 by robkey
Replied by robkey on topic Oil leak
it seems to be from the trans end of the rear shaft any ideas to wot seal i need to replace guys
20 Sep 2018 04:25 #196142 by Lambert
Replied by Lambert on topic Oil leak
There's a silly design flaw with the early push button propshaft where a hole allows the oil out. Have a search on here as it's a fairly easy fix.
20 Sep 2018 06:27 - 20 Sep 2018 06:31 #196144 by yakuza
Replied by yakuza on topic Oil leak
Lambert wrote: There's a silly design flaw with the early push button propshaft where a hole allows the oil out. Have a search on here as it's a fairly easy fix.
I thought that was the intermediate shaft between the gearbox and the transfer box, letting the Gearbox oil out?
This picture is the rear prop shaft isn't it?
The shaft seal under the transfer box output flange i guess. Should be most wet on the transfer box by the flange if so.
The oil drops fly around at speed making everything aft of the leak look like a disaster.
Mine leaks a bit btw as mine is a 2005. later 2009-10 or so got a new design.
Tried to seal it with silicone but not a complete success..
I just refill for now while looking for a new(er) shaft.
Last edit: 20 Sep 2018 06:31 by yakuza.
  • robkey
20 Sep 2018 15:24 #196155 by robkey
so is it nothing to worry about ? check it today in work no oil from seal on trans box just from the rubber on the prop is there a way to get in it and is it just old grease not oil ?
21 Sep 2018 04:33 #196167 by Lambert
Sorry my bad I hadn't realised it was the that propshaft.
Time to create page: 0.176 seconds
