31" for the jimny and regear
10 Sep 2018 06:34 - 10 Sep 2018 06:35 #195834 by yakuza
Replied by yakuza on topic 31" for the jimny and regear
Thanks to zookbob, all above correct. I was on my phone so did not find the links and stuff to post in my reply :)
Also one option is to change the diffs from your 4.09 to diffs from a manual VVT jimny at 4.3
Last edit: 10 Sep 2018 06:35 by yakuza.
10 Sep 2018 06:41 #195835 by yakuza
zukebob wrote: That is the kit that I was commenting on. It is supposed to be very good quality (no personal experience) but is not appropriate for your Jimny.
[/url]
well the quality is not completely great in my opinion. As an engineer working with gearboxes for ships I have some experience with gear sets and these make a lot of noise. there was plenty more when they where new and this shows that the gears had not been grind to fit and i suspect there to be some scuffing between the gears inside and some noise from the chain drive. could be my chain was worn of course but the noise is way beyond what i would send out of our factory. But it works, and the gear ratio is spot on for my 235 wheels.
Could even be ok for bigger wheels but i lik to go low.
But i guess the quality is no worse than other brands as a ground and polished gear set probably is way too pricy for a after market kit :)
The following user(s) said Thank You: zukebob
  • Jeep4life
10 Sep 2018 07:04 #195836 by Jeep4life
Replied by Jeep4life on topic 31" for the jimny and regear
you guys are awesome and super professional!!
zukebob, i think my diffs are 4.3,
i think i will stay with the push button, rocklobster mean i need
to buy another t case from samurai? or am i wrong ? do you have a link explaining what is exactly?
i looked on the trialjimny kits, the COMP one looks like the one for my needs. i just want to be able to cruise at 90-100 on highways and get nice and slow moves while im on the rocks.
this one can achieve that ?
again, thank you all !
10 Sep 2018 08:14 #195837 by zukebob
You are correct. The Rocklobster would mean replacing your current transfer case. I never planned to go to a Rocklobster so I never really researched the details of the swap. You could try using the search function of the forum to see what you can find or wait for someone who has done the work to detail the steps.
As far as the COMP set of gears from Trialjimny are concerned, I put in some of the numbers on the grim jeeper site we mentioned. It certainly seems that the gear ratios wouldn't be terrible for highway. Your 90-100 would be at a little lower RPM (but would likely take you a little longer to get there). The low range is definitely for crawling.
Based on Yakusa's comments, you may want to do a little more research still before making a purchase. I was a little surprised by his experience with gear noise (although Rocklobster has a reputation for the same). Like Yakusa, my career was as a mechanical engineer, although my background was with a company that designs and produces military vehicles for the U.S. Army and Marines. What I learned early on, and I'm sure Yakusa will agree with me, is that experience trumps theory every time. Try to get more info before you make a final decision......unless the gear noise makes no difference to you.
10 Sep 2018 09:10 - 10 Sep 2018 09:12 #195839 by Riccy
Replied by Riccy on topic 31" for the jimny and regear
A 'Rocklobster' box is a hybrid SJ box made using parts from a SJ410 and SJ413. There is a conversion some people do called a mini-lobster, which is basically just a SJ413 box stuck into a jimny, but this has no real improvement in low-box.
For a non VVT jimny its pretty straightforward to put a lobster box in, you just need the intermediate prop and front prop from the SJ (use the front prop as a rear on the jimny, existing jimny front is fine as it is). There is also a mounting cradle and speedo ring you need for the box to go into the jimny.
With VVT jimnys I found the intermediate prop was different to the SJ so I had to have a custom one made (shorter than the original jimny one). The spline count on the gearbox output shaft is different to the SJ prop. This also lowered the gearing way too much as the VVTs have different gearbox and diff ratios.
In the end I decided to swap the lot (gearbox, diffs, props) and use the rocklobster box as this was the only way to get it useable on the road. It now sits about 4000 RPM when doing 60mps (100KPH) roughly, which i am happy with. Lowbox is really low as well :-) I think the ratios in my rocklobster are 1.5 in high and 4.13 in low. This is with 31" tyres on.
Last edit: 10 Sep 2018 09:12 by Riccy.
  • TomDK
10 Sep 2018 09:40 #195840 by TomDK
Replied by TomDK on topic 31" for the jimny and regear
Almost correct. The mini lobster is when using the 410 transfer box in the Jimny. It's has a slightly lower low ratio that the 413/Jimny.
Haven't read the entire thread. But for anything more than greenlaning I wouldn't hesitate getting a rock lobster transfer box or even lower gearing for 31-32" tyres. It just makes a world of difference.
Time to create page: 0.430 seconds
