cylnder head
10 Aug 2018 07:55 #194962
by paul2u
cylnder head was created by paul2u
i noticed first that the engine seemed to be running off a cylnder on tick over but ok on higher reves and driving , i then noticed that my water level kept dropping and needing to be topped up , i took out number 2 plug to find it fowled up as this was the cylnder that was missing on tick over , i put in a brand new plug for it just to be the same , coild packs ect have been checked and ok , i also have water coming from the exhaust , i loose about one pint of water on 60 miles , i am thinking the head gasket or worse as there seem to be no aparent leaks , i am minded to take of the head , what do you guys think cheers
- Thank you received: 1939
10 Aug 2018 08:15 #194963
Replied by Lambert on topic cylnder head
Sounds like a reasonable assumption.
The following user(s) said Thank You: paul2u
10 Aug 2018 08:16 #194964
by Busta
Replied by Busta on topic cylnder head
A compression test will confirm, but definitely sounds like a head off job. Which engine? If it's a DOHC save the hassle and swap the whole thing for a 1.6
10 Aug 2018 11:43 - 10 Aug 2018 12:49 #194982
by paul2u
Replied by paul2u on topic cylnder head
its a very good jeep as in body work both underneath and on top so its well worth dooing
is there a lock up kit for the cams and crank shaft its a M13A 1328CC 2005
Last edit: 10 Aug 2018 12:49 by paul2u.
10 Aug 2018 12:50 #194983
by paul2u
ITS m13a 1328 cc
10 Aug 2018 13:49 #194986
It's only a marginally more difficult job to put in a 1.6.
Time to create page: 0.192 seconds
