Car beeping when i turn right ?????
  • Phattaff
29 Jul 2018 16:39 #194696 by Phattaff
Car beeping when i turn right ????? was created by Phattaff
Hi All
Not had the Jimny long and yes it's a great car, not sure why but the car has started beeping when i turn right. Anyone out there know what the problem might be?????.
All the best
Phattaff
  • wombat
29 Jul 2018 16:44 #194697 by wombat
Replied by wombat on topic Car beeping when i turn right ?????
Hi, is the car fitted with a towbar and electrics ? If so could be a wiring fault activating the beeper for the towing indicators. I would check the towing socket fist for corrosion/water ingress
  • Phattaff
29 Jul 2018 17:31 - 29 Jul 2018 17:31 #194699 by Phattaff
Replied by Phattaff on topic Car beeping when i turn right ?????
Cheers for the reply Wombat, No tow bar fitted that's why i'm puzzled, also it's only just started to do it today and doesn't do it when i indicate left????
Last edit: 29 Jul 2018 17:31 by Phattaff.
  • wombat
29 Jul 2018 19:03 #194701 by wombat
Has it ever had a towbar fitted,if so has the wiring just been cut off, there are different wires for each side indicator. Where is the beeping noise coming from ?
  • Phattaff
29 Jul 2018 19:25 #194703 by Phattaff
Wombat
Not sure if it has had a towbar fitted (where would i need to look to find out) the beeping seems to be coming from right side below steering wheel
30 Jul 2018 03:58 #194706 by Lambert
Sounds like a ground fault in the indicator switch that's setting off the headlights warning buzzer.
Time to create page: 0.192 seconds
