Would a Jimny be good for me?
- gman88667733
14 Jun 2018 14:46 - 14 Jun 2018 14:46 #193438
by gman88667733
Would a Jimny be good for me? was created by gman88667733
I am looking at getting a Jimny. My thinking behind this is that I live down a very uneven, steep track, which gets very slippery to drive up and down and then I have to park on a field that is thick mud and big bumps that my Skoda Yeti bottoms out on. I only drive 7 miles to and from work each day, and then I do a few trips a week out that are a bit longer. I want something fairly cheap, that I don't mind about scuffing up or scratching (getting very bothered about my more expensive Yeti getting scratched). What is the fuel economy like? I'd probably stick AT tyres on it to get the full experience. I would also like something that is fun to drive.
Does a Jimny sound like it would suit me?
Cheers.
Cheers.
Last edit: 14 Jun 2018 14:46 by gman88667733.
14 Jun 2018 16:03 - 15 Jun 2018 04:54 #193445
Replied by yakuza on topic Would a Jimny be good for me?
I believe you score a good 7/10 on the Need A Jimny Scale. You only loose a point because of the fuel economy wich comes down to what you compare it to. compared to another small petrol car you will find better, but compared to other terrain capable cars with stiff axles, i think there is none with as good fuel economy.
You will get another two points if you have no very large space requirements or need it to be very comfortable on-road.
Good luck buying a Jimny!
Last edit: 15 Jun 2018 04:54 by yakuza.
14 Jun 2018 16:59 #193451
Replied by Riccy on topic Would a Jimny be good for me?
Sounds like a Jimny is ideal for you
MPG is around 30 for a fairly standard one, modified to hell will be nearer 12mpg (like mine :whistle: ).
Road comfort is poor, but if you still have the yeti then use that for longer trips and the Jimny as a hack to run about in.
Bin off the back seats and it turns into a little van. Jimnys always make people smile so its defo got the fun factor.
14 Jun 2018 18:36 #193458
Have you been looking at anything else. You say you have a Yeti, did you want that to do the rough work when you bought it? What is fairly cheap - cheap to buy, cheap to run. Ground clearance motors to me seem to be getting harder to find these days.
Replied by helijohn on topic Would a Jimny be good for me?
gman88667733 wrote: I am looking at getting a Jimny.
Cheers.
- Thank you received: 1983
14 Jun 2018 18:57 #193462
Replied by Lambert on topic Would a Jimny be good for me?
A Jimny will go places a yeti can't even see so pottering down an unmade track isn't going to bother a Jimny. Where are you in the country someone local might be able to give you a freebie demonstration for a cup a tea?
- gman88667733
15 Jun 2018 08:15 - 15 Jun 2018 08:27 #193472
by gman88667733
Replied by gman88667733 on topic Would a Jimny be good for me?
I would get rid of the Yeti. The DSG gearbox is rubbish.
We also have a Kia Sorento that would be for longer trips.
The Yeti currently gives me 35mpg in this decent weather and was about 30 in the winter. I don't mind too much if it isn't the most comfortable thing to be in as most of my driving is pottering around.
I originally bought a 4x4 Yeti which ended up giving me no end of issues and so I swapped it in for a 2wd 1.2L petrol DSG one. In hindsight, changing to a 2wd automatic was a mistake as it is awful at slow speeds. In an ideal world, I'd want something a bit more plush inside and a bit more engaging to drive, but I wouldn't even know where to start. I stand to lose a good few thousand when selling the Yeti, so i'd need to buy something cheaper probably. I would also have loved to get another deisel as I liked the driving characteristics, but my mileage would wreck a DPF. This brings me to the Jimny. I don't fit in a stock one as my legs are too long, but I think with the seat extender plates, I may just fit.
I don't know whether 4wd is necessary, but my current Yeti slides around a lot on the grass and the tracking going up out of the property.
Any advice would be appreciated.
Last edit: 15 Jun 2018 08:27 by gman88667733.
Time to create page: 0.203 seconds
