Led light bars (do they last ) and best route for cables from roof.
30 May 2018 19:07 - 30 May 2018 19:21 #193067 by Scimike
I have a space on my roof rack for a LED roof bar or spotlights and have seen some fitted on this forum. Guardian Angel fitted a 126W light bar, plenty on ebay for around £30....but is it still working?
Anyone else got one and can offer any feedback on if they work for more than a few weeks.
An alternative I am considering is LED daylight running lights mounted high.
I am not that concerned about if they illuminate the way ahead well, my interest is focused on if they last, my own experience of LED bulds is they are c#$p, working only for a few months before slowly failing.
A second question on how are people running the cable from such a light into the vehicle without compromising watertight ?
Thanks
Mike
Last edit: 30 May 2018 19:21 by Scimike.
  • rappey
31 May 2018 17:02 #193099 by rappey
Led,s can last a very long time, but you pay for that ! There are many led spot and floodlights that are very cheap but heat kills them off..
I run some super bright leds in my boat but have them restricted in output which will prolong their life (I hope)
ie, 12v downlighter for a boat, from china = £3 From a yacht chandlers =£45 .You get what you pay for !
Boats have water tight fittings to allow cables into the boat so have a look at whats available?
31 May 2018 17:39 #193102 by Riccy
I agree that the quality of whats available is really poor Chinese tat.
I used to have a 32" curved led bar on the roof-rack. It was on there for about 3 months and had already started to shed its powder coat with alu rot (aluminium rust?). The lens had also fogged so IP rating is not as stated.
Then a pikey helped themselves to it one night. Didnt get the brackets as i binned them and made my own :-) However they are a theft target so its not been replaced.
The light output from it was pretty good for off-road and way too much to use on the road, so a compromise between ultimate output and actual quality is needed.
For running the wire, i binned off the aerial and ran it in there. its also fairly easy to run a wire up a snorkel. Have since replaced the aerial and binned the roof rack :laugh:
  • Daniel30
31 May 2018 21:41 - 31 May 2018 21:44 #193106 by Daniel30
Got to say I think it's the luck of the draw with the Chinese stuff can't remember where I got mine from but thet were cheap, still look good as new and work great, regularly blasted with the jet hose and no problems so far, I ran my wire down the snorkel in some ribbed tubing and cut a slot in the plastic just behind the bonnet.
Can't attach a pic for some reason :(
Last edit: 31 May 2018 21:44 by Daniel30. Reason: Spell
  • mdog18
01 Jun 2018 10:20 #193118 by mdog18
I fitted my LED light bar about 2/3 weeks ago. Bit soon to start analysing long term quality but so far I can say it has worked brilliantly, with no signs of failure. I went the aerial wiring route as I have no snorkel, but either way works :)
02 Jun 2018 08:15 #193145 by 1390_taz
I have four 6" LED lights fitted to a roof bar. The cable is in split spiral conduit running past the aerial and down the snorkel.
Into the engine bay
Time to create page: 0.164 seconds
