Storage compartment instead of factory trim on the rear door
25 May 2018 20:33 #192950
by Bosanek
I am considering removing the factory plastic interior trim from the rear door and installing some tailor-made storage compartment.
Has anyone done this? I would really like to see some interesting solutions and ingenious ideas.
The compartment must not decrease the space in the trunk / boot. In other words, it must not be too thick.
Are there any pre-fabricated solutions?
25 May 2018 22:40 #192952
Replied by helijohn on topic Storage compartment instead of factory trim on the rear door
I once had a pair of speakers mounted on a soundboard that I made but TBH there wasn't a lot of room back there.Bosanek wrote: I am considering removing the factory plastic interior trim from the rear door and installing some tailor-made storage compartment.
- Thank you received: 1988
26 May 2018 06:45 #192955
Replied by Lambert on topic Storage compartment instead of factory trim on the rear door
All i have done with mine is removed the heavily moulded plastic and replaced with a flat hardboard trim. It makes more available space in the back that is more versatile than a fixed cubby arrangement.
- X8GGY
26 May 2018 16:04 - 26 May 2018 16:05 #192963
Replied by X8GGY on topic Storage compartment instead of factory trim on the rear door
When you take the plastic trim off there isn't much useful room to build cubby holes / storage, as there's lots of strengthening bits, a wiper motor and the lock mechanism all in the way -
You'd have to start cutting the inner metal panel out to gain any space? And that would weaken the door with the spare wheel hanging off the back?
Last edit: 26 May 2018 16:05 by X8GGY.
26 May 2018 22:20 - 26 May 2018 22:21 #192970
by Bosanek
Replied by Bosanek on topic Storage compartment instead of factory trim on the rear door
Well the reason why I am thinking about some DIY interior trim on the rear door is because (believe it or not) I managed to lose the original interior trim!
While I was swapping parts between my old and new Jimny, I left the old trim somewhere outside and someone probably took it away.
I had to transplant the trim from the new car to the old car to be able to sell the old car, and now I am without the trim on the new car.
No automotive junk yard employee over here knows what a "Suzuki Jimny" is. Is that a motorcycle?
So I have to think something out.
Last edit: 26 May 2018 22:21 by Bosanek.
27 May 2018 09:17 #192976
Replied by Daniel30 on topic Storage compartment instead of factory trim on the rear door
Maybe flat board it and attach some sort of cargo net so that you can still use it for storage.
Time to create page: 0.188 seconds
