Anti ageing compounds
17 May 2018 15:08 #192771 by Lambert
Hi all. Ok so after the last winter being as rough as it was it's time to refresh the under armour of Ermintrude. When she was new the first thing to happen was a liberal coating of waxoyl. This has been topped up yearly for the last 7 years. The only reason for this product was that buzzweld didn't exist at the time. My plan is over the summer to use my evil jetwash to really clean the old stuff off as much as it will without separating the body and then to rectify any issues before another heavy coating. But and this is the question, what's the best stuff to reapply? I'm not going to have the time to get it clean enough to buzzweld so it'll be a waxy coating whatever I use but which are worthwhile and which aren't?
Thanks in advance.
  • GRAYWOLF
17 May 2018 15:33 #192772 by GRAYWOLF
Replied by GRAYWOLF on topic Anti ageing compounds
I would be inclined to reapply waxoyl again, if you havent got the time for buzzweld, i am at present in process of buzzweld my axles and diff cases etc; as i had them dropped while i was fitting new suspension..
Worth the effort.!!
  • Daniel30
17 May 2018 16:33 #192773 by Daniel30
Replied by Daniel30 on topic Anti ageing compounds
Well if the stuff you have been applying for the last 7 years has worked better the devil you know.
  • helijohn
17 May 2018 17:55 #192775 by helijohn
Replied by helijohn on topic Anti ageing compounds
Lambert wrote: But and this is the question, what's the best stuff to reapply?
For me it is a no brainer. Waxoyl all the time.;)
  • gilburton
17 May 2018 18:12 #192777 by gilburton
Replied by gilburton on topic Anti ageing compounds
Does the stuff my wife has for her face count??
17 May 2018 18:34 #192778 by facade
Replied by facade on topic Anti ageing compounds
Dinitrol gets better reviews than waxoyl. I dinitroled the Jimny and it doen't seem much better than waxoyl tbh, but apparently you need to reapply every 2 years whatever you use. (Naturally I haven't)
It always worried me that the bottom of the waxoyl tins used to rust through so quickly in the garage too- considering how much waxoyl runs down the outside of the tin you'd expect the bottom of the can to be well protected :whistle:
Time to create page: 0.281 seconds
