Very specific question on vented braking.
03 May 2018 13:00 #192357
Replied by yakuza on topic Very specific question on vented braking.
Or if you wanna feel safe, you buy new brake parts friends. It's not so expensive.
I bought everything new for an SJ. Five door Vitara 92-98 -ish. brackets and all.
With the Vitara calipers you will get the bleed niple on the side, so you will have too loosen the caliper and turn the bleed vent up to get the air out of it..
- Thank you received: 1970
03 May 2018 13:12 #192358
Replied by Lambert on topic Very specific question on vented braking.
If it's available new it will be new, if it's available high performance it will be. Not cutting corners with the brake system.
03 May 2018 14:40 #192359
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Very specific question on vented braking.
Something else to consider with vit calipers, is they are larger so clearance and wheel size my be an issue dependant on your setup.
My jim ran vit calipers on the rear when i got it, i swopped them out for jimny fronts. The vit cal[pers (even with new carriers with the correct grease. In fact i tried various different types of grease in the end) kept seizing up.
Never had that with the jimny ones. I have to unbolt them and sit them on top of the disc should i need to bleed them due to the location of the bleed nipple. but they don't give me any issues.
03 May 2018 15:51 #192361
Replied by Daniel30 on topic Very specific question on vented braking.
Could you get a decent machine shop to drill jimny discs?
- MadsV
03 May 2018 16:23 #192362
by MadsV
Replied by MadsV on topic Re:Very specific question on vented braking.
Anyone got part numbers for the caliper hanger?
- minitehnicus
03 May 2018 17:33 #192364
by minitehnicus
Replied by minitehnicus on topic Re:Very specific question on vented braking.
Caliper assy P/N:
55101-84A01-999 left
55102-84A01-999 right
There is no part number for caliper hanger.
