Bent rear door.
  • 1066Boy
11 Apr 2018 18:19 #191585 by 1066Boy
Bent rear door. was created by 1066Boy
Ok hears a question for all you Jimny people. Recently I did a competition. Part of it included crossing a stream. As I dropped in, my spare wheel hit the bank and bent the door. :( I have bent the top back in by hand and its close enough. The bottom is bent outwards a little (enough to put the boot open light on) so the bottom left courner needs bending back in about 1-2". Ideas about the best why to achieve this? Thanks Allan.
  • helijohn
11 Apr 2018 19:01 #191591 by helijohn
Replied by helijohn on topic Bent rear door.
1066Boy wrote: Ok here's a question for all you Jimny people. Recently I did a competition. Part of it included crossing a stream. As I dropped in, my spare wheel hit the bank and bent the door. :( I have bent the top back in by hand and its close enough. The bottom is bent outwards a little (enough to put the boot open light on) so the bottom left corner needs bending back in about 1-2". Ideas about the best why to achieve this? Thanks Allan.
Depends on how cosmetically good you want the result to be but I'd use brute force. I'd possibly find a wall and with some 4x4 timber against the wall and a bit of lever work then reverse into the wall.
  • 1066Boy
11 Apr 2018 19:04 #191592 by 1066Boy
Replied by 1066Boy on topic Bent rear door.
Did think about that but wanted to ask before doing it.
  • helijohn
11 Apr 2018 19:13 #191594 by helijohn
1066Boy wrote: Did think about that but wanted to ask before doing it.
It's tricky cos it is easy to make it a whole lot worse but I have done it to doors and tailgates; never quite the same though afterwards.
12 Apr 2018 04:09 #191604 by Lambert
Replied by Lambert on topic Bent rear door.
Bit more involved than just reversing into a wall. Get a suitable length of stout timber and brace the door open against the body allowing enough room for you to work in the gap. With a small ratchet strap gently pull the corner straight. Use a spreader on the end of the strap against the door to mitigate pinhead dents. Be gentle.
The following user(s) said Thank You: 1066Boy
12 Apr 2018 14:00 #191622 by X8GGY
Replied by X8GGY on topic Bent rear door.
A 'new' door from a breaker?
Time to create page: 0.164 seconds
