Bent rear door.
- 1066Boy
1066Boy wrote: Ok here's a question for all you Jimny people. Recently I did a competition. Part of it included crossing a stream. As I dropped in, my spare wheel hit the bank and bent the door.
I have bent the top back in by hand and its close enough. The bottom is bent outwards a little (enough to put the boot open light on) so the bottom left corner needs bending back in about 1-2". Ideas about the best why to achieve this? Thanks Allan.
Depends on how cosmetically good you want the result to be but I'd use brute force. I'd possibly find a wall and with some 4x4 timber against the wall and a bit of lever work then reverse into the wall.
- 1066Boy
1066Boy wrote: Did think about that but wanted to ask before doing it.
It's tricky cos it is easy to make it a whole lot worse but I have done it to doors and tailgates; never quite the same though afterwards.
- Thank you received: 1983
- Thank you received: 923
