Extra weight on boot door
30 Mar 2018 22:10 #191070 by Busta
Replied by Busta on topic Extra weight on boot door
I've had no problems with a 215/75r15 on a standard steel rim on the rear door for over 50,000 miles. I'm fairly sure it's not 10kg heavier than the original tyre though. Maybe 3 or 4kg extra?
  • helijohn
31 Mar 2018 06:25 #191078 by helijohn
Replied by helijohn on topic Extra weight on boot door
Garuuu wrote: Ive got steel wheels from Jimny bits and bf goodrich a/t tyres (215/75/15). With these heavier wheels i was wondering if i would encounter any problems with tbe added weight on the boot door.
Thanx for the info!
No.
Door hinges tend to loosen up a little through wear etc. I kept mine on my gold Jimny well lubricated after having a green Jimny which had badly worn hinges but that was used by a golf club owner and for some reason its hinges had gone.
31 Mar 2018 21:32 #191106 by yakuza
Thanx for the info!
Thru the winter season I got a ski rack on the spare wheel. Have to have a steel wheel to make it fit. Driving on bad roads with two pairs of skis makes a slight knocking noise from the door because of the extra weight. I think the sheet metal wobbles where the bracket is mounted.
I guess this adds 10 kg for the rack and 10 more with the skis.
In summer i have my 235 BFG on alloy wheel on there. No problems with any of the setups.
My bracket is slightly modified due to the 235.
Sent fra min E5823 via Tapatalk
