Front brake caliper
  • wombat
24 Mar 2018 16:17 #190816 by wombat
Front brake caliper was created by wombat
Hi all, anyone know of a good supplier of new calipers, can't have car immobile so going to fit a new caliper and rebuild the old one at my leisure
Cheers, Ian:)
24 Mar 2018 17:56 #190819 by jackonlyjack
Replied by jackonlyjack on topic Front brake caliper
Just phone round local motor factors
The cheapest i found in my area was davmac at
100 for the pair
The following user(s) said Thank You: wombat
  • mickt
24 Mar 2018 20:14 #190822 by mickt
Replied by mickt on topic Front brake caliper
Item # 162888197511 on ebay A front pair for £95.85 posted New from Germany.
  • wombat
24 Mar 2018 21:45 #190824 by wombat
Replied by wombat on topic Front brake caliper
jackonlyjack wrote: Just phone round local motor factors
100 for the pair
cheapest i found at local factors was £145 for one, (must try harder , lol )
saw these but only lists as fitting up to 2005 model, will have to contact them to see if they fit a 2008
thanks for replies, Ian
  • Jimx5
24 Mar 2018 22:33 - 24 Mar 2018 22:56 #190825 by Jimx5
Replied by Jimx5 on topic Front brake caliper
Funny you should bring this topic up, only today i started to jack my car up to do the gearbox oil, anyway i found the nearside front wheel was not rotating freely, in fact it was very tight.
Wheel off, caliper removed, found the slider tubes where not as free as they should be so they came out and got polished with wire wool then refitted with red brake grease, next step was to compress the piston which again was quite tight so i pumped the piston half way out, peeled the lip seal back and polished the piston as best as possible while rotating the piston, this was then pressed home a couple of times while coated in red brake grease.
I know the caliper needs stripping, cleaning and resealing which is a job i've done quite a few times.
Anybody know where i can get a caliper kit?
Car has had a good run since and there are no leaks.
Edit....found them on the bay.
Last edit: 24 Mar 2018 22:56 by Jimx5.
25 Mar 2018 06:57 #190837 by mlines
Replied by mlines on topic Re:RE: Front brake caliper
Jimx5 wrote: Funny you should bring this topic up, only today i started to jack my car up to do the gearbox oil, anyway i found the nearside front wheel was not rotating freely, in fact it was very tight.
Also in the BigJimny store!
Time to create page: 0.193 seconds
